  #31 (permalink)
Old 10-23-2007, 10:03 AM
99Smokin73Stroker 99Smokin73Stroker is offline
Send a message via AIM to 99Smokin73Stroker Send a message via Yahoo to 99Smokin73Stroker
Originally Posted by F-350MAN View Post
there used to be a guy on her quite a bit and he ran a 2000 or 2001 7.3 pushin 800+ I will try to get more details this was a couple yrs ago.
That may be dockboy, he's been on here a few times I've seen.
Originally Posted by CSIPSD View Post
I'm not bashing... Just want people to realize the 7.3 will never be the HP king... Its a great motor, and the best workhorse of the bunch... but she is not built for hp...
Now imagine the repercussions had I said that!
  #32 (permalink)
Old 10-23-2007, 10:07 AM
CSIPSD CSIPSD is offline
Dockboy is the only one that has really come close... But it was on spray... and a Dodge can do 800 on fuel relatively easy...
  #33 (permalink)
Old 10-23-2007, 10:16 AM
bfloyd4445 bfloyd4445 is offline
Originally Posted by LPstroker View Post
I was reading the November 07 issue of diesel power and there doing the Diesel Power challenge. The winner of the Dyno test was a Dodge with 956 HP and 1,605 Lb-ft, #2 was another dodge with 852 HP and 1,453 Lb-ft, #3 was a Duramax with 750 HP and 1300 Lb-ft. Finally a Ford was #4 with 715 HP and 1,179 Lb-ft, but it was a 6.0L. The highest 7.3L in the competition was 601 HP and 1,077 Lb-ft. My question is how much horsepower and torque can a 7.3L make? O and a Duramax won the whole competition.
Hey, that 6sec 1/4 miler mentioned in DP magazine this month is putting out 1,400 hp! The 7.3 has lots of potential
  #34 (permalink)
Old 10-23-2007, 10:17 AM
Well, uh, yeah!
  #35 (permalink)
Old 10-23-2007, 10:22 AM
Originally Posted by SCUFFY828 View Post
, geez , aint that aweful, tear a engine all to heck when its not even broke in yet
Yes it is. Hey scuffy, why don't you pick up a core and start building it into a rocket. That way you can have the use of your SD and take your time tricking out the core engine. I'm seriously thinking of doing something like that. If common rail injection is now available for a psd these engines will start really kicking butt.
  #36 (permalink)
Old 10-23-2007, 05:54 PM
powerstrokin87 powerstrokin87 is offline
Send a message via MSN to powerstrokin87
wasnt there a stroker drag car in last months diesel power with like 4 turbos? i cant remember for sure or how much hp ill have to look it up again.
  #37 (permalink)
Old 10-23-2007, 08:47 PM
makaveli200369 makaveli200369 is offline
Im curious...even if a common rail kit came out for these engines does that include a new ECU to control it? Or new program
  #38 (permalink)
Old 10-23-2007, 08:54 PM
strokin_early_99 strokin_early_99 is offline
John Wood Nut Swinger
And all the documents for a second on the house as well..........
If it ever happens it aint gonna be cheap.
  #39 (permalink)
Old 10-24-2007, 07:20 AM
why wouldn't the old one work? All it does is send the electronic signal to fire the injectors right? If a kit comes out your gonna see some changes for sure.
  #40 (permalink)
Old 10-24-2007, 09:08 AM
If I recall correctly newer common rail injection systems inject fuel at multiple points in the cycle. I know they do this to make the engine quieter. I also thought the ECU's using common rail control the rail pressure and other variables for optimum fuel mixture....but maybe you're right...it might not be needed. Maybe its only getting the hardware to work and the stock ECU can control it. Hope someone can chime in on this.
