  #11 (permalink)
Old 10-21-2007, 05:26 AM
payne5757 payne5757 is offline
about how many miles can I expect out of my injectors with my mods? I dont plan to make anymore considerable power gains so what she has is almost all shes gonna have.
  #12 (permalink)
Old 10-21-2007, 02:34 PM
bryanbrown bryanbrown is offline
I've got 235K, and I run mine really hard. I push the oil changes, filter changes, etc., and it's still running like a champ. 1 clutch, 1 water pump, and a few various sensors. I'm vowing not to retire her until I hit 500K. Hopefully I'll make it
  #13 (permalink)
Old 10-21-2007, 02:38 PM
sldghamr sldghamr is offline
i have heard thru the grapevine that the 7.3 has gotten pretty close to a 1million miles with very few if any problems
  #14 (permalink)
Old 10-21-2007, 02:39 PM
that would be awesome
  #15 (permalink)
Old 10-21-2007, 02:56 PM
alabamafrog alabamafrog is online now
Powerstroke Techie
If you want it to last I’d recommend a good clean running intake like the Baldwin PA2818 to save from dusting the engine and doing the fuel tank and prepump filter mods to save the injectors by keeping air and trash from a bad load of fuel out and a temp gauge on the tranny with Amsoil or some other good synthetic fluid in it. I have had to rebuild the engine, replace the injectors, replace the tranny, alt, water pump, ball joints, tie rods, brake rotors, turbo, starter (twice), pcm, door actuators, etc, etc, and mine has 210,000 miles on it now. I'd guess that just the parts bill for mine is over $12,000 so far with me providing all the labor and shopping around for prices.
  #16 (permalink)
Old 10-21-2007, 03:26 PM
LPstroker LPstroker is offline
As stupid as my Girlfriend's brother is, he doesn't take care of his truck at all but he has 279K and has only done injectors, and a tranny.
  #17 (permalink)
Old 10-21-2007, 03:43 PM
ksttac ksttac is offline
what is the fuel tank and filter mod
  #18 (permalink)
Old 10-21-2007, 03:49 PM
vitalidle vitalidle is offline
Desert Shield/Storm Vet
Here is a good writeup on the fuel tank mod. Welcome to guzzle's In-tank Hutch Mod Web Page Here is lots of info for intakes Intake Information
  #19 (permalink)
Old 10-22-2007, 05:45 AM
Powerstroke Techie
I can’t look at the above link cause it is blocked by our company computer. Here is a link to the pics I took while doing mine. Shutterfly | View Shared Pictures
The factory quick connect fitting work fine under pressure but tend to leak air in under vacuum so I deleted all of them on the suction side of the pump by running rubber fuel line with worm hose clamps. The factory mixing chamber on the pickup foot tends to leak air in at low tank levels and looks like it puts air returning from the engine right back in the system. I deleted it and replaced it wits a metal pipe. I also removed the screen from the foot and put the large fuel filter inline before the pump where it is very easy to check and/or change. The replacement filters are about $5 and will greatly extend the life of the $25 factory filter and help save the system from contamination. From what I understand air, water, and thrash are what ruins injectors more than miles.
  #20 (permalink)
Old 10-22-2007, 05:59 PM
Strokethis9 Strokethis9 is offline
i have a 2001 7.3 and i have 154000 and its had a water pump and an alt. and thats it
