Old 10-20-2007, 04:49 PM
portlandmaine portlandmaine is offline
Let it sit...now it won't start!
Hi all....I let my 2001 Econoline 350 7.3 sit for a couple of months and now it won't start. I threw a new battery in it but it won't turn over. Any ideas?
Old 10-20-2007, 04:56 PM
Goose Goose is offline
Sponsored By MOM
Send a message via AIM to Goose Send a message via Yahoo to Goose
no cranking?
Old 10-20-2007, 05:09 PM
it almost starts then clicks as if it's not getting enough power, even when it's being jumped by our other car.
Old 10-20-2007, 05:19 PM
vitalidle vitalidle is offline
Desert Shield/Storm Vet
Check all your battery connections and make sure they are tight. Does the van have a two battery setup? If it does you might have one bad battery draging the good one down.
Old 10-20-2007, 05:32 PM
Okay. Now my husband says that the battery was new but had also been sitting for about two months. But we're jumping it and still no start, even after it sits for a while hhoked up to the running truck. What's happening?
Old 10-20-2007, 05:35 PM
I would charge the battery up with a charger overnight and then try it again. Your battery will be run down enough after a few months. Its possible your connections aren't making good contact with the jumper cables.
Old 10-20-2007, 05:36 PM
Also is it a good heavy duty battery with lots of cranking amps for a diesel engine?
Old 10-20-2007, 05:37 PM
Logan Logan is offline
The Fat Mod
Do you have a battery charger? This trucks have to have something like 10.4 volts min. to crank. If you are not getting that, you will need to charge it. Also, you can try using some WD40 to help it along. Use it like you would starter fluid. BUT NO STARTER FLUID! That may get ya headed in the right direction.
Old 10-20-2007, 05:39 PM
The Fat Mod
Good point, I always get batteries with at least 1000 CCA for these trucks.
Old 10-21-2007, 02:38 PM
bryanbrown bryanbrown is offline
vital may be on to it, does it have two batteries? I've had one of my batteries go bad twice, and it will still crank, and seems to nearly start. When I put two new batteries in, it fires right up. Also, drain your fuel filter, or just change it.
