Old 10-20-2007, 04:30 PM
ksttac ksttac is offline
washing the engine?
is it ok to wash my 7.3? i know it needs to be cool and not running the motor is stock ie stock airbox etc. is there something i can spray on it that anyone would reccomend to remove old oil and grime. im new to the diesel any comments would be appreciated. the engine is not too dirty, i just want it to be clean.
thanks
Old 10-20-2007, 04:34 PM
Lord Tauk Lord Tauk is offline
Send a message via ICQ to Lord Tauk Send a message via AIM to Lord Tauk
WD-40 works well to just wipe up, don't have to worry about water.
Either or, simple green or any degreaer of your choice, garden hose and some plastic grocery bags to wrap around critical parts, air filter, electronics, etc. etc. Be sure to get off the degreaser as well as you can. Be critical where you hose and how much pressure you use.
Compressed air to dry is always helpful.
Maybe find yourself a non-alcoholic engine shine to use afterwards.
Old 10-20-2007, 04:48 PM
is it ok to spray down in the engine valley with high pressure to clean out the oil residue? basically is there anywhere i shouldnt spray?
Old 10-20-2007, 04:59 PM
vitalidle vitalidle is offline
Desert Shield/Storm Vet
I wouldn't high pressure spray anywhere in the engine compartment. Use some good engine degreaser and just use a garden hose or low pressure spray and it will take care of the valley. There is a drain hole for the valley so just let it drain.
Old 10-20-2007, 08:50 PM
thank you for the help.
Old 10-20-2007, 08:52 PM
Also be careful with the degreaser as it can be rough on plastic parts also
Old 10-20-2007, 08:55 PM
do you have a reccomendation for the degreaser?
Old 10-20-2007, 08:57 PM
Like Lord Tauk said simple green is good. I use this stuff from nappa can't remember the name off the top of my head......purple somthing.
Old 10-21-2007, 04:13 AM
00f250 00f250 is offline
USMC - 6017
Send a message via ICQ to 00f250 Send a message via AIM to 00f250 Send a message via Yahoo to 00f250
Purple Power, maybe?
Old 10-21-2007, 06:42 AM
chrispaine chrispaine is offline
do you think that foaming Gunk cleaner is alright?
