  #11 (permalink)
Old 10-21-2007, 08:26 AM
alabamafrog alabamafrog is offline
Powerstroke Techie
It might be a bad thing but I let mine cool completely and spray it down with simple green then use a 1200psi pressure washer set on fan pattern and wash everything. I then let it dry for a long time (like over night) before trying to start it. Never had a problem so far. I have also used the foaming Gunk but I like Simple Green better.
  #12 (permalink)
Old 10-21-2007, 11:47 AM
ksttac ksttac is offline
does the simple green get the gunk out of the valley as well
  #13 (permalink)
Old 10-21-2007, 02:15 PM
Lord Tauk Lord Tauk is offline
Send a message via ICQ to Lord Tauk Send a message via AIM to Lord Tauk
Elbow grease is usually a good influence to any cleaners.
  #14 (permalink)
Old 10-21-2007, 02:27 PM
bryanbrown bryanbrown is offline
I use the car wash sprayer, just so long the motor has cooled off. It works pretty good
  #15 (permalink)
Old 10-21-2007, 04:40 PM
Blue01F250 Blue01F250 is offline
Tournaments Won: 1
water won't hurt anything as long as you let it dry up!
I would do like alabamafrog -- make sure the engine is cooled down -- then go for it and don't start it until its had time to dry!
  #16 (permalink)
Old 10-21-2007, 04:58 PM
is a couple of hours good on the drying time
  #17 (permalink)
Old 10-21-2007, 06:49 PM
Stroker7.3 Stroker7.3 is offline
a little diesel fuel on the grease and a pressure washer will clean it right up. all these guys worry to much i wash it with the engine on so i know it will run. no need to dry it... what happens when you drive down the road when its raining?
  #18 (permalink)
Old 10-21-2007, 07:06 PM
Tournaments Won: 1
Driving down the road in the rain is not the same as putting a high pressure power washer to the engine bay....
  #19 (permalink)
Old 10-21-2007, 07:15 PM
but it still gets wet... anyways it doesnt effect anything
  #20 (permalink)
Old 10-21-2007, 07:21 PM
Tournaments Won: 1
the thing you are trying to avoid is with a pressure washer, it FORCES water past the weather seals on the plugs and connections... Rain just gets the outside of stuff wet -- a pressure washer can force water into the connections, possibly causing shorts
