  #11 (permalink)
Old 10-19-2007, 09:48 PM
mschn99 mschn99 is offline
Originally Posted by strokin_early_99 View Post
Another guy I know has been running 435hp for over a year without any problems. Another fellow was pushing 415hp and popped the block. It has a lot to do with tuning. I do not know about other tuners but I know DP tuner has done a lot of cylinder pressure testing. DP is the tuner for the guy with 435hp. The other guy tuned his own with the SCT system.
first of all...listen to howard...he knows what hes talkin bout...
it doesnt matter what tuner you run...although some may be "safer than others"....if you go over 400 RWHP you are playing with fire as he said above. It only takes one split second over what the motor is capable of to bend a rod...or worse.... its not anything i would want to mess with...with a $8000 motor....
