Old 10-19-2007, 08:51 AM
Jimmy78 Jimmy78 is offline
Question Smoke and power loss
I just recently replaced my glow plugs and noticed that two of my injectors on the drivers side were disconnected. I plugged them in and noticed a huge difference in power. It has been a week and I am noticing smoke pouring out of the exhaust pipe when I step on the accelerator while driving. Mostly over 2000 rpm. It seems as though I am starting to lose power again. Any suggestions?
2002 F350 7.3L PSD
Old 10-19-2007, 09:56 AM
Grant Grant is offline
Your truck may be defueling because it reached too high of a boost pressure. Which is right around 22psi. I had the same problem you need to get a boost fooler.
Old 10-19-2007, 06:10 PM
How do I install the turbo boost fooler onto the truck?
Old 10-19-2007, 06:16 PM
vitalidle vitalidle is offline
Desert Shield/Storm Vet
Are you stock still or do you have a programmer or chip?
Old 10-19-2007, 09:43 PM
I am still stock as far as I know. I bought the truck used and I am still new at this mechanic thing. I am not even sure to locate the chip.
Old 10-19-2007, 09:44 PM
Where to locate the chip.
Old 10-19-2007, 09:46 PM
mschn99 mschn99 is offline
if they were disconnected at the valve cover....then you need to replace that harness. the connectors sag and thats what lets them disconnect.....
Old 10-19-2007, 09:49 PM
strokin_early_99 strokin_early_99 is offline
John Wood Nut Swinger
Take a look at your computer here to see if there is a chip in it. The chip installation instructions are the best I can do. It shows what it looks like with a chip and how to take the PCM out. Here: http://www.dp-tuner.com/Documentatio...stallation.pdf
And like Marc mentioned. At the least check the harness plug on the valve cover for now. The plugs on the injectors have a lock to keep them from coming unplugged. Were the metal clips still there?
