  #11 (permalink)
Old 10-19-2007, 08:03 PM
red99powerstroke red99powerstroke is offline
I want as much HP as I can get without risking to blow it completely sky high. 30' goose neck with tractor=25,000#+ over all rig
  #12 (permalink)
Old 10-19-2007, 08:44 PM
strokin_early_99 strokin_early_99 is offline
John Wood Nut Swinger
Copy my set up. I would tow anything and never worry about it. The most I have towed was 22,300lb and that was from Cali to Texas and back. Not a care in the world on the trip. The only one little hick-up was I did not tighten down a intercooler boot and it popped off going over the rockies. That was all me and not the truck failing.
  #13 (permalink)
Old 10-19-2007, 08:53 PM
What type of boost do you run? I can get as much as 50 out of the turbo I have now
  #14 (permalink)
Old 10-19-2007, 08:59 PM
vitalidle vitalidle is offline
Desert Shield/Storm Vet
Are you sure you gauge is working right?
  #15 (permalink)
Old 10-19-2007, 09:01 PM
Nevermind I read that wrong your just saying your turbo is good for 50psi I think?
  #16 (permalink)
What turbo are you running now? Stock injectors with a larger than stock turbo and you can get 50psi? That one is tough to believe. Very tough. I must be misunderstanding something here.
I saw 51psi today and hope to see more when I get the fuel system installed this weekend.
  #17 (permalink)
Old 10-19-2007, 09:06 PM
Beans Diesel Performance or https://amjperformance.com/ They both have injectors and turbos. Im doing the switch to the 99.5 to my early 99. I have the ball buster turbo but like you im still wondering what kind of injectors would be a good match because all my truck does is pull.
The ball buster turbo is good for 50psi? At what CFM?
I did find where someone said it was good for 500hp but have never herd of any at that power level. I would say your turbo is good for 40psi, not 50. The garrett BB and the TN BB are good for up to 40psi so that is where I get the 40psi. Plus if you are looking to go over 40 I would recommend head studs. To get to this power level you would have to run hybrid injectors and the EGT's would be over 1500* I would guess. To tow with that set up would be very doable with tuning.
On edit: I did some research and you will have to do some research yourself here: Ball Buster Turbo - Page 2 - Powerstroke Nation
From the reading I did I found that the most power this turbo will dyno is 390hp, not the 500hp they claim.
  #18 (permalink)
Old 10-20-2007, 06:01 AM
no no the guy I bought the turbo from said the turbo will produce that much boost but the wast gate is set at 32 I have no idea I dont have the turbo on yet. My truck as of now is all stock and it gets around 30 but wanted to upgrade turbo and injectors
  #19 (permalink)
Old 10-20-2007, 06:44 AM
I would doubt that turbo could ever make 50psi. Most of the upgraded bolt on turbos like this one are 40psi turbos. If you do some research out there as I posted above, you will find some very informative and maybe rather disappointing info.
Yes the turbo is an upgrade over stock but nothing like the Garrett ball bearing.
Go ahead Joe, give me crap for saying garrett.
