02 7.3 HPOP - Ford Powerstroke Diesel Forum
Old 09-06-2012, 11:34 AM
02 7.3 HPOP
How hard is it to remove to the hpop cover to the reservoir what is involved, is there a gasket? I want to check for leak down. Thanks
Old 09-06-2012, 11:37 AM
Well, just to watch for a leak-down condition can't you just use the plug and "dip" the reservoir?
Old 09-06-2012, 12:00 PM
Where is the plug because that's all I want to do is check the level?
Old 09-06-2012, 12:02 PM
ADMIN AND TECH
you can pull the allen plug out or even the oil sending unit right on top the reservoir and run a thin object ,screwdriver etc. down to the bottom and as long as its no more than 3/4 of an inch down from the top after an overnight sit your fine
Right on top of resovoir. right side.
Old 09-06-2012, 12:05 PM
Ok thanks I'll look into this I just never done it before and I would like to check it. Have a little bit of a hard start happening.
