7.3 weight?
I was wondering how much a 7.3 weighs? I know the GVWR is on the inside of the drivers door but there was a few different numbers there. Could someon tell me what number is the total weight?
Just curious if anyone could help Thanks |
like the motor? the 7.3 is a motor, that motor came in an OBS and a SD. What cab configuration? you are asking a very vague question.
The motor weighs around 1000lbs. The super duty body style equiped with a 7.3 can weigh up to 8000lbs+, not really sure on an obs, most seem around 6500-7000ish |
^Only thing I'd add is a 7.3 wet is closer to 1200lbs. Otherwise spot on.
my OBS CCLB DRW with half tank in both tanks and a loaded toolbox weighed in at 8400 lbs.
Mine weighed in on the scale with about 1/4 tank of fuel 7,837ibs
My '01 SC, 8ft box, 4x4 manual trans. crosses the scales at 8k +/- 200lbs depending on fuel load and what tools are in the back.
