NEED HELP!!!! - Ford Powerstroke Diesel Forum
post #1 of 11 Old 09-02-2012, 10:07 AM Thread Starter
Send a message via AIM to kyleh20
NEED HELP!!!!
So i have not had my truck for about 2 weeks now and i need to fix it and i heed help!
The original problem was that i was driving normal up a small hill i heard a pop and it started to run really rough at idle and through the rpm range but smoothed out a little it felt as the high rpms were seen. but it sounds like half the engine is running
First thing was i thought i blew the up pipes as they were really loose and a lot of soot around them. So i ordered a t4 mount and everything o the turbo and everything is new.
That didn't fix anything it ran a little better but then when i drive if i get on the gas pedal it build boost quick and blows off the intake y but before that if i let go of the pedal it surges a lot i don't know if that is normal or not.
But then i was very confused so i found some other people saying check CPS, ICP, IPS so i changed all of them new and that didn't fix anything it may be a little smoother but the original problem is still there.
Next i checked i IDM i ohmed out all the connectors from the plug to the injectors, i got no shorts and all injectors were between 3.9 and 4.4 ohms.
Following that i don't know what to do i have a scanner but for some reason i can not get the live data to show while it is running but please help i need to get my truck fixed
2002 F-250 7.3l 190K
str8 piped exhaust
T4 mount s366 turbo
6637 W/ zoodad
TW custom tunes
18" rockstars with nitto terra grapplers
Pioneer avic-f700bt
Piller mount gauges autometer pyro/boost/tranny
F650 dash w/ fuel pressure and air pressure
Fisher 7.6 HD plow
BTS Transmission
And lights everywhere
kyleh20 is offline
post #2 of 11 Old 09-02-2012, 10:20 AM
I'd agree with your first thought. Did you check your CAC pipes and boots? Is it holding boost or building boost and then dropping off?
Sent from some piece of advanced technology that I don't understand!
2005 - Excursion - Eddie Bauer - 4x4
185amp DC Power Engineering alternator
BPD oil cooler and cold weather package
Updated standpipes and dummy plugs
Edge Insight CTS with fuel pressure
No more STC fitting in the HPOP
Updated fuel pressure spring
Updated turbo oil drain
Updated turbo oil feed
Sinister Coolant Filter
BPD 58V FICM
Dual Batteries
Rotella T6
CAT ELC
The best 6.0 advice I've ever seen...
Fishermedic is offline
post #3 of 11 Old 09-02-2012, 10:26 AM Thread Starter
ya all my boots are new ishe i inspected all of them none are cracked or anything. but when i get on the trottle and it blows a little smoke it is like blowing smoke rings... like only half the motor is running right if that makes sense
str8 piped exhaust
T4 mount s366 turbo
6637 W/ zoodad
TW custom tunes
Pioneer avic-f700bt
Fisher 7.6 HD plow
BTS Transmission
kyleh20 is offline
post #4 of 11 Old 09-02-2012, 11:40 AM Thread Starter
well found my problem bent push rod # 7 cylinder i think the passenger side closes to the firewall
str8 piped exhaust
T4 mount s366 turbo
6637 W/ zoodad
TW custom tunes
Pioneer avic-f700bt
Fisher 7.6 HD plow
BTS Transmission
kyleh20 is offline
post #5 of 11 Old 09-02-2012, 11:40 AM Thread Starter
now how to fix it should i just put new push rods in or do i have to rebuild the whole motor what should i do?
str8 piped exhaust
T4 mount s366 turbo
6637 W/ zoodad
TW custom tunes
Pioneer avic-f700bt
Fisher 7.6 HD plow
BTS Transmission
kyleh20 is offline
post #6 of 11 Old 09-04-2012, 06:44 AM
wtf happened?
85_305 is offline
post #7 of 11 Old 09-04-2012, 08:59 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
if you need parts for that 7.3 let me know and i can sell you the parts, smokin prices
just email me
2000-7.3L is offline
post #8 of 11 Old 09-04-2012, 06:06 PM Thread Starter
the exhaust rocker carrier cracked building to much pressure then bent the intake pushrod
the problem now is it is running a little smoother but it is rough and it is smoking a lot white smoke and i dont know what it is now
a compression test or something
glow plugs
injectors
what should i do now??
str8 piped exhaust
T4 mount s366 turbo
6637 W/ zoodad
TW custom tunes
Pioneer avic-f700bt
Fisher 7.6 HD plow
BTS Transmission
kyleh20 is offline
post #9 of 11 Old 09-06-2012, 12:32 AM
dentexpowerstroke's Avatar
Is the white smoke coolant or diesel? That is going to be the deciding factor on what your next step is.
Sold 2001 f250 ccsb 4x4 400/400, dual terminators, swamps 80mm bfh, headers, bts and all the usual supporting mods. 715hp fuel only.
06 f250 ccsb king ranch
12 f250 lariat ultimate
dentexpowerstroke is offline
post #10 of 11 Old 09-06-2012, 01:16 PM Thread Starter
im not quite sure i am compression testing the cylinders right nowto get an idea but i am pretty sure all the glow plugs are good cold the all ohmed out no shorts or opens
str8 piped exhaust
T4 mount s366 turbo
6637 W/ zoodad
TW custom tunes
Pioneer avic-f700bt
Fisher 7.6 HD plow
BTS Transmission
kyleh20 is offline
