Originally Posted by BigRed02
Hey CHenry, is there a way to create a warmer for the "oil" tank that you can plug in all the time, Such as a block heater, or am I off base and you already have a system like that?
Sure you can add pad heaters to the tank but the thing is, theres no reason to heat the whole tank (mine is 90 gallons). All that needs heated is the oil traveling up the fuel puckup tube and through the lines, though the filter and to the injectors. It uses engine coolant to heat all this system so the engine has to get hot and open the thermostat before hot coolant is circulated to the tank where the first point of heat is at the fuel pickup line in the tank. I plug my truck in year round...In the summer it's not needed to start easier of course but I'm heating the coolant so when i get in in the morning, the ambient temp outside is 80, and the engine coolant is already 140*. Now I only have to drive about a mile untill the thermostat opens it switches over to vegi. Plus, the the fuel rails are my final heat exchanger so i need the engine heads to be nice and hot before i run any oil through them and to the injectors.
