  #11 (permalink)
Old 11-14-2005, 09:26 PM
Ramsmoker Ramsmoker is offline
Powerstroke Techie
Cool Trans temp
I don't knock the quality of banks products. I guess it all depends on your bank account. For the price of a trans command you can put all sonnex valves, a external cooler, filter and temp gauge. I just rebuilt my 4R100 from my superduty. This gave me the chance at valving the front pump with the Sonnex high flow valve. Lockup hits like any other gear now. A must if you have the pump out. The extra cooler helps a ton. I put mine off to the right side of the grill with a 6" electric fan. The bottom line is the least amount of shifting and quicker the gear change, the longer your trans will last.
  #12 (permalink)
Old 11-15-2005, 12:12 AM
Mike OB Mike OB is offline
I did install a Banks torque converter and the trans command, I think the trans command cost me 325 and the torque converter ran about 995. I got a 250 return credit for my old converter I also added a B&M deep pan and a temp gague. It like never gets up over 200 degrees, and I pull a 28RK Coloraido 5th wheel - even up Mt Shasta at 70 miles per. My hope is the tranny will last as long as the engine. Mike OB
  #13 (permalink)
Old 11-15-2005, 12:49 AM
Powerstroke Techie
Talking trans
The temps your getting are awesome for pulling like that. It does go against some of the dinosaur oil gurus. Most detergent packages work there best at 205 degrees. I don't think I ask what the optimum temp was for the amsoil atf. 200 to even 225 shouldn't permanetly alter the oils propertys. I have seen mineral gear oils that had seen 300. They also looked like water in the drain pan.
  #14 (permalink)
Old 11-20-2005, 06:07 AM
f250powerstrokeman f250powerstrokeman is offline
here i put this on my truck and made all the difference in the world here is the link http://www.bankspower.com/Transcommand.cfm
  #15 (permalink)
Old 11-20-2005, 10:34 PM
Hey I am glad you are injoying that positive shifting and lack of slipage. Mike OB
  #16 (permalink)
Old 11-29-2005, 01:39 AM
GOZAR GOZAR is offline
Im am looking to get the trans command, so theroretically my edge shouldnt fool with the trans command right? Anyone reccomend any decently priced Torque Convertors?
  #17 (permalink)
Old 11-29-2005, 04:02 PM
super_stroke super_stroke is offline
Power Strokeaholic
my trans command was a p.o.s. it would shift into o/d come out and go right back in.we unhooked it for about 400 miles ,no problem. hooked it back up and 1 mile, only 1 mile it started again. sent it back, they tested it. said nothin was wrong. put back in and got the same thing. so its bolted to the truck w/ the bypass plug in doin nothin.
  #18 (permalink)
Old 11-29-2005, 06:59 PM
Look on e-bay, you can find a four clutch torque converter for the price of a two clutch and it has a long warranty - I also found that there is a transmission shop in Phinox that gives four (4) year warranty? parts and labor. they claim they come with a bullet converter for less than $2000, never used one but it looks good on the feed back. Mike OB
  #19 (permalink)
Old 11-29-2005, 07:02 PM
I am going to start a new thread about transmissions, it is a learning thing that I hope will answer many questions about 4R100 transmissions. Mike OB
  #20 (permalink)
Old 11-29-2005, 09:56 PM
Powerstroke Techie
Cool answers
I have heard alot of people raving about the transcommand. I have played around, burned up and rebuilt one of my 4R100's. I never got the shift firmness or coverter lock with an external control. My rebuild has fantastic shifts and converter lock. I do use my own lockup device. The sonnex shift valves, pressure valve and front pump to converter lock pressure valve. I didn't use the sonnex springs because my trans had a Fairbanks kit already. I don't know how much the banks unit cost. I only have $300.00 in the parts to rebuild the trans.
