NEED HELP! - 203* Thermostat wont seal
I am trying to install the new 203 thermostat and aluminum houising but I cant get a good seal on the housing.
A gasket cam with both but I am only using the one under the thermostat. Am I supposed to be using one between thermostat and housing? ANy advice greatly appreciated! |
Check the directions. I believe it should indicate thermostat in the hole, gasket, then the housing sanwiches it all together nicely. Watch your torque. I believe 15 ft lbs.. Just did it a week ago worked fine.
I used gasket maker to do mine.
I made my Samsung SGH-I997 send this. |
I thought gasket went below. Duhhh! ![]() Thank you for the help! |
I had to use rtv to get mine to seal properly, or else it would always have a little dribble...
same with mine
I torqued the billet aluminum housing to spec and it does not leak a drop!
Replaced hoses, flushed x2, installed 203* thermo and coolant filter from DieselSite and refilled with Rotella ELC! She is happy! Thanks to everyone for the responses. |
