New 7.3 full of issues - Ford Powerstroke Diesel Forum
Old 08-26-2012, 02:36 PM
So i just bought this truck for $2800 I knew going into this that it was gonna be a project but it will be worth it. I also have a 6.0 and have gone threw the pleasures of bulletproofing. Im in no rush to fix it but i only wanna do it once.
So the previous owner said he was driving it and it lost all power and the check engine light came on. He drove it home and parked it. All he knew was there is fuel in the coolant.
So It got dropped off at my house this morning with dead batterys ugh. I drained the coolant and it stinks of fuel
After charging the batteries i got it started. Definatly has a miss, sounds like a bad injector. After replacing a couple fuses i got the OBDII port working and pulled the following 4 codes
P0381 GLW PLG IND CIR ER
P0472 EXH BK PRS S CIR LO IN
P0562 SYS VOLT LO
P1316 INJ CIR IDM CODES DET
So i plan to start tearing it down to the top of the heads and pull the injectors. If i see rust or discoloration on the injectors ill pull the cups. Im also gonna get the injectors checked. Any one have any other advice or can explain the codes or expereince with these problems? Thanks
Old 08-26-2012, 02:43 PM
Keep us informed with more pictures!! Thank you
Old 08-26-2012, 03:03 PM
I believe that's injector cups
Old 08-26-2012, 03:36 PM
That's what I was thinking... was reading an issue of Diesel Power this morning where they replaced the injector cups, and the symtoms you're discribing sound exactly like that... fuel in the coolant. Be nice if that's all the issue is, you got one heck of a deal on that truck!
Old 08-26-2012, 04:44 PM
Injector cups or o-rings.
Old 08-26-2012, 04:54 PM
Thats a good looking truck. I like the older chevy 4X4 stickers haha.
Old 08-26-2012, 04:55 PM
I don't think I've ever heard of orings causing fuel in coolant. thats usually oil in fuel or fuel in oil I believe.
Old 08-26-2012, 06:32 PM
I think if the first oring takes a crap I could see it
Old 08-26-2012, 06:33 PM
It old my wife those were Chevy stickers , she thought I was full I crap lmao
Old 08-27-2012, 06:35 AM
So last night I got the whole drivers side of the motor torn down to the top of the valve covers . Before I did the I got a quick video of it running. http://i116.photobucket.com/albums/o...E7C4CCD150.mp4
