Diesel Fuel in Coolant - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 20 Old 10-12-2007, 09:24 AM Thread Starter
Hi;
I have a 2001 ford tow truck with a 7.3 motor. I filled up yesterday and today I have diesel fuel in my coolant over flow resorvoir. I dont have any diesel in my engine oil or transmission, just my coolant system. Any idea what could be causing this?
Thanks
komobu is offline
post #2 of 20 Old 10-12-2007, 09:55 AM
JYB018's Avatar
I am having the same problem right now. From what I understand you have a cracked injector cup, a brass part the injector sits in. My trucks been in the shop a week. You need a special tool to fix it with out pulling the heads.
Good Luck!
White 06 F-350 Lariat
Limo Tint
Smoked Recon cab lights, rear brake lights
and turn signals
Leveling Kit
37"x13.5" Toyo M/T's
AFE Stage 2 intake
edge insight w/ EGT probe
Magnaflow 4" stainless exhaust turboback
SCT X3 with Innovative custom tunes
JYB018
JYB018 is offline
post #3 of 20 Old 10-27-2007, 05:16 PM
pooldini's Avatar
2nd time fuel in coolant
I found my coolant had fuel in it about 2 months ago. I took it to the dealer and they replaced all the cups/caps on the left head ( they pressure tested and said there was a leak on that side ). everything went and felt good for the last two months, I thought I was loosing some power the last couple of weeks, when I looked under the hood today I found there was more fuel getting into the coolant. Now I have to consider another 3k$ to replace the caps/cups on the other side, or replace the entire engine!!!!(OUCH).
pooldini is offline
post #4 of 20 Old 10-27-2007, 06:11 PM
Cracked cups is what causes this.. If you are inclined, you can purchase the special tool from OTC.
mcnik is offline
post #5 of 20 Old 10-28-2007, 07:58 AM
PwrStrokinDually's Avatar
Send a message via AIM to PwrStrokinDually
Most likely an injector cup issue. And you don't need to buy an OTC tool. You can use an over sized bolt that will screw in to this and carefully pull it out with a pulley puller. Re-installation is extremely important that you put the seals in the correct spots on the external parts of the cup otherwise you'll have the same issues. This task isn't something I'd recommend for someone that's somewhat mechanically challenged. I wouldn't take it to the dealership, but I would definitely find someone in your area who's familiar with the motor to help you out. Like someone from this board or another forum.
Danny Om
01 SC PSD Dually (build date 08-00 w/ PMRs), 8" Edge, dual F&R Doetsch aluminum shocks w/ resevoirs, 37" SSR on all 6 tires, 2" (hub & wheel centric) wheel adapters by Fearless Fred Goeske, Fabtech racing track bars.
Fully built motor w/ B-codes, GT42R, and Terminator HPOS with Remote-IPR.
Auto Enginuity equipped for local assistance.
PwrStrokinDually is offline
post #6 of 20 Old 10-28-2007, 09:00 AM
well i just finished replacing all eight cups on my early 99. 2,4 were leaking put i did not want this to happen again so i took the time to replace them all. i made my own puller set out of stuff in my shop. go buy a 1 1/4 x 14 tap. the one i bought was 47 bucks. then went to a bolt store and bought the bolt that matched the pitch. i paied 5 bucks for the bolt. i then cut the head off of the bolt to shorten it because you do not have much room on the back two holes and the one next to the heater box. one top of the bolt i welded a long nut not sure what you call it but it is a nut that is 3/4 inch long to thread into. my slide hammer i made out of some left over 1/2 rod that i welded a washer on one end and then started sleeving tube that i had laying around and then welded a bolt to the end that would thread into the nut on the bolt. total lenght is around 7-8 inches and weighed 2lbs. this little set cost 52 bucks and worked like a dream. after got a feel for the first one i was moving along. you will get a feel for it after one or two. this is not that hard of a deal. it took me a day to do all eight and get the truck going. so you know i am a self tought rench and fabracator. so jump in and do it. few little tips...stuff a small pice of rag in the bottom of the cup to keep shaving out of the piston, use some cutting fluid. even though they are brass the sleeves are tougher than you think.
eaton34 is offline
post #7 of 20 Old 12-14-2007, 10:39 PM
Thanks eaton. Good tips.
jackpine savages is offline
post #8 of 20 Old 07-08-2009, 05:40 PM
I also have a 2002 7.3 with diesel in the coolant. I have been told it has cups by one mechanic and does not have cups by another. Can anyone tell me for sure if the 2002 7.3 has cups?
glamprecht is offline
post #9 of 20 Old 07-08-2009, 09:37 PM
layson's Avatar
Quoted: 84 Post(s)
Yes it does.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #10 of 20 Old 07-09-2009, 07:45 AM
tubular031's Avatar
Does anyone have any pictures of the cups? or how they are in the motor? I dont think I have ever seen them before.
Just a basic 01 F350 CCLB SRW -Good from a far but far from good
tubular031 is offline
