Transmission notch leak
I have a fluid leaking from a notch under my transmission. The fluid is clear with no noticeable odor. I'm not sure why a clear fluid would be leaking from the transmission. I checked the transmission fluid and the level looks good. It leaks even on short trips. Thanks in advance for the help.
The answer is,,,, because it's Not coming from your transmission
![]() Has this just started happening since it got Hot out? And you're using the AC now? The ONLY clear, odorless, liquid you're likely to find has just Got to be Water... |
Or brake fluid.
Is there a brake line down there near it? (It's getting dark out and it's about dinner time or I'd go check. I haven't turned the AC on the last few times I've run it just to be sure that wasn't it. Could it be a coolant leak and I just can't detect the green because the drops are so small?
The brake lines run down the driver's side frame rail. I know it's not recommended, but dab your finger in the clear fluid, and taste it. If it tastes sweet, it's anti freeze. Close to no taste, and it's just water. Tastes like complete as_s and you've gotta rinse your mouth out? Brake fluid.
Use a white paper towel then you will be able to tell what color it is, how about a pic
Anyone up for a taste test? Sure glad I can figure it out before I have to go that far... tho I know what water and anti-freeze taste like (accedentily), I have yet to try brake fluid... Back on topic... hope you find the identity to your mystery fluid... without needing to call poison control. |
I don't think you can be leaking brake fluid for very long without being aware of it... (I though you say it's been happening for several "trips")
I guess rubbing between your fingers would show if it had any "oily" content though. |
I took a sharpie and drew a line on the coolant reservoirs of the brake fluid and coolant to mark their current spots before I went to the store. Two twenty minute drives didn't show any any noticeable changes in fluid level but I did get three pictures of the leak. I think it's the line to the right of the transmission that's spraying it onto the bottom of the transmission, they're both wet. The substance feels oily but I'm afraid it's from a degreaser I sprayed two days ago and didn't rinse off thoroughly enough.
I was going to try the taste test but I don't think we're done having kids and my wife wants them to come out normal (a relative term in my family). I caught some of it on a paper towel but I can't tell any color so I'm waiting for it to dry, hopefully that helps it be more noticeable. And yes, I've driven it a few times with no adverse feelings in the brakes so I doubt that's it (the reservoir is topped off as well). Maybe the truck is just well hydrated....
Gonna bet it's a/c condensate. Mine drains from that general location.
