Tranny cooler upgrade - Ford Powerstroke Diesel Forum
Old 06-18-2012, 02:06 PM
I will be installing a 31 row 6.0 tranny cooler in my 00 7.3 and have a questions for you guys which have done this. Can I just drop the cooler and slid the new one in or do I need to remove my bumper and grill? Also how much more fluid do ya'll have to add? Thanks
Old 06-18-2012, 04:36 PM
Send a message via AIM to rufushusky
Great write up...
http://api.viglink.com/api/click?for...13400662549091
Ugly link but works...
Old 06-18-2012, 05:00 PM
The grill removal is a must. I believe the front bumper removal is optional, but it gives you a lot more room to play with. For the little effort it takes to remove the bumper, it is worth it. I believe I lost somehwere around 1 - 2 quarts. FYI when you do the install, the 90 degree tabs on the bottom of the cooler should face the engine.
Old 06-23-2012, 06:53 AM
is there any problem fitting a 31 row in sense it sits higher?
Old 06-23-2012, 10:01 PM
Send a message via AIM to ClemsonStang
I changed my cooler when i did the 05-07 front end swap. pulling the stock cooler out with just the grill of has to be a bear.
Pulling the bumper off makes it much easier. if you have a second set of hands, its worth pulling the 6 bolts to do it. especially for figuring up the new hose routing.
