Black CPS HELP
Ok I found a black one today in a dead block. It is from a 99 don't know if early or not. Here are the numbers 1825899. The other number is 0926KC93. Please say this is the original black one?
Black CPS is marked as: 1825899
Grey CPS is marked as: 1876735C91 Dark Blue CPS is marked as: 1876736C91 Black, Grey, & Dark Blue Cam Position Sensor Perdels Test - Diesel Forum - TheDieselStop.com |
Thank you I got the original black one yes. I just tested it with a set of keys and picks it up but will drop them but it is so strong it sucks itself right onto it keys are heavy. There are few nicks in it due to prying it out hopefully I am good. Also I just ordered the orings from guzzle for the cps.
AE scanner where can I get one how expensive what do I need I want to start my own work I am beginning not to trust mechanics?
Why did you have to pry it out? you should have been able to wiggle it or twist it out.
Anyway, congrats on finding an original black; hope it works great for you. Technically you should be able to use the oring from your current cps, I would think. maybe not since tip diameter is larger, IDK. you can get Ae about anywhere. Price will be pretty much the same everywhere. I bought mine from riffraff |
