to all members with leveling kits; please share advice - Ford Powerstroke Diesel Forum
post #1 of 11 Old 06-13-2012, 05:06 PM Thread Starter
Trying to put 35" trail grapplers on my f-250 and new front shocks. Through all of the feeds im reading about the mini packs, and a leafs. having to mess with the pitman arm and an adjustable trac bar.. Which kit has worked the best for you and why? what would you suggest? i'm not afraid to spend the money once and be done with it. please send me in the right direction.
THANKS!!http://www.powerstroke.org/forum/ima.../icon_ford.gif
salajoey is offline
post #2 of 11 Old 06-13-2012, 06:06 PM
Kitten7.3L's Avatar
lift
I replaced my front stock leaf springs with 2.5" leaf springs from Rough Country to level my F350 SRW. Added Bilstein HD's and Cooper Discoverer ATR's 315/75/16s on stock 16"X7" wheels. The tires do scrub on leafs at full turn. I am trying to remedy this now. Plenty of clearance for the tire in the wheel well however.
2001 F350 XLT SRW extended cab. 2007 grill/headlight/Turn signal tow mirrors conversion. Large Filter NAPA 6637, straight piped, 35"s on 16"s, leveled with 2" Tough Country leaf springs. PHP 6 position Phoenix Gryphon tunes.
Kitten7.3L is offline
post #3 of 11 Old 06-14-2012, 05:56 AM
Quoted: 4 Post(s)
Feedback Score: 5 reviews
You need a min 3" lift for most 35" with V code fronts..plus a adj track bar..best riding kit would be a 3" hanger kit...and longer shocks. since you have a F250 you will also need taller rear blocks and U bolts..plus longer shocks.
CT Performance, Inc. is offline
post #4 of 11 Old 06-14-2012, 07:23 AM
audiocontr's Avatar
I took mine out as the previous owner didnt plan properly. The 3" springs raised the front higher than the rear and messed with my steering. SO much better with new stock springs.
Nonconformist. Functionality over bling.
My three rules for 7.3l troubleshooting: 1) Replace CPS and keep a spare. 2) Replace FPR and know your fuel pressure. 3) Hook it to a scanner and check for codes.
audiocontr is offline
post #5 of 11 Old 06-15-2012, 08:43 AM
jshalala's Avatar
I am installing a 3 inch mini spring pack and extending the track bar bracket on my truck this weekend. When I get home tonight its going up on jacks and I hope to finish it Saturday morning.
Ill let you know how it works out.
I picked up the leveling kit from Newton Lifts on ebay. good guys to deal with. Full 3 inch spring pack and all new hardware is included.
2003 Ford F250 6.0 powerstroke 4x4.
ZF6 manual trans, ext cab short bed
deleted, 4 inch exhaust, gauges, traction bars
16x10 Weld wheels wrapped in 33s
Early 1999 Ford F250 7.3 Powerstroke 4x4
Crew cab short bed
straight pipe, intake
jshalala is offline
post #6 of 11 Old 06-15-2012, 09:26 AM
Quoted: 4 Post(s)
DO not space a track bar bracket with spacers and longer bolts unsafe and not needed as you will get bump steer...get a adj track bar.
post #7 of 11 Old 06-15-2012, 12:22 PM
jshalala's Avatar
I have a couple of guys running the same kit as I got with no problems. Spacers are a cheaper alternative to a new track bar bracket. But yeah I wouldnt mind an adjustible track bar but so far the other trucks havent needed it. I'll run it for awhile and see what happens.
Crew cab short bed
jshalala is offline
post #8 of 11 Old 06-15-2012, 12:27 PM
Koda22's Avatar
Quoted: 5 Post(s)
I got a mini spring pack, and my 35s will rub if im turning hard and on a slope other wise no problem.....i think its a 2.8 or something, dont remember, but i did get an adj trac bar....got everything off ebay, and it was around 200....I think....cant remember
Koda22 is offline
post #9 of 11 Old 06-15-2012, 01:05 PM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
quick tricks performance has a custom 2.7 inch lift for 90 bucks. clears 35's
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx custom tuned, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Lighting, No Limit S2 Intake, Tinted, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
post #10 of 11 Old 06-15-2012, 04:41 PM
gone6.0's Avatar
Quoted: 26 Post(s)
I also have the mini pack $154, no adj track bar has been on truck for 70,000 no problems I only have 33's, but i believe 35's may work but may rub when turning.
gone6.0 is offline
