front and rear diff oil change. - Ford Powerstroke Diesel Forum
Old 06-06-2012, 06:43 AM
I need to change my front and rear diff oil I am new to the Ford diesel I have a 2000 f250 7.3 I was wondeing what oil and how much for front and rear thanks for the help
Old 06-06-2012, 01:38 PM
75w-140 in the rear and 75w-90 in front. i know the rear holds about 4qts, don't know on front. might want to sand and paint the rear cover, mine was eat up with rust
Old 06-06-2012, 02:17 PM
yeah the front takes 3 and the rear holds 4
Old 06-06-2012, 03:40 PM
The reason I'm changing fluid is really to change the covers so it does not rust through and leak with out me knowing. Thanks for the help
Old 06-06-2012, 03:44 PM
What's the best fluid to use do I need one with friction enhancer
Old 06-06-2012, 05:19 PM
Get the friction modifer from Ford. Oh, and make sure you buy a synthetic gear oil. I had Royal Purple in my truck for 50K, and just switched to Lucas oil. Both were/are great.
Old 06-06-2012, 05:23 PM
First, what differentials do you have?
Old 06-06-2012, 05:45 PM
It's a 2000 F-250.. There's only one set he can have. Dana 50 up front, Sterling 10.5 in the rear.
Old 06-06-2012, 05:57 PM
if you go with aftermarket covers, most increase fluid capacity. also, if you use a good synthetic oil you may not need friction modifier(i didn't using some amsoil i had left over from something else)
Old 06-06-2012, 07:07 PM
How often do you change this fluid and how do you know it needs to be changed?
I have a 99 F250, do I have the same differentials?
