99 F250 Bleeding Sequence
I haven't got my manual yet, so I am hoping that someone can tell me the sequence to bleed/flush my brake system. Thanks.
when you do bleed get a hose long enough to go back into master cylinder reservoir and when no more air coming thru close off bleed valve. this allows you to do it on your own
Always start with the caliper farthest from the master cylinder. It's usually the right rear (passenger side) wheel on most cars and trucks. Once you see the new fluid coming through tighten the bleeder and switch to the left rear. Next is right front and lastly left front.
Regards, Dwight |
Thanks. I will be doing it tomorrow. I will be flushing the whole system so I'm not going to worry about put it back in the cylinder, it is very dirty!
