tail lights and guage cluster lights are out? - Ford Powerstroke Diesel Forum
Old 06-01-2012, 03:20 PM
ive checked all the fuses and nothing is wrong. i still have headlights all blinkers and brake lights just no tail lights and guage lights. and the warning beeping noise that goes off when you leave your lights on doesnt work either. i was told by someone that it was my headlight switch so i changed that and i still have the problem. any ideas?
Old 06-01-2012, 03:34 PM
Either a bad wire in the steering column, that's common.
Maybe the GEM module too.
How'd you check the fuses?
Old 06-01-2012, 03:47 PM
i checked every single fuse that was in my truck with a fuse checker thing.. like u touch it to the fuse and the light comes on.. if you were in my shoes how would you go about fixing this
Old 06-01-2012, 04:19 PM
Get a test light and test each side of each fuse first. Or ohm meter and ohm out each fuse.
If you test light them, both sides should light up if they are good. If not, the constant 12V side will light up, and the other won't if it's blown.
Ohm meter will just test continuity. If there's unlimited resistance, it's blown.
