97 vs Early 99 7.3? Same thing? - Ford Powerstroke Diesel Forum
Old 05-30-2012, 09:50 PM
Ive never seen this question up before, only e99 vs late 99. But whats the difference between the obs 7.3 vs the early 99 7.3? are they the same thing?
Old 05-31-2012, 01:31 AM
Lots of differences...
body, frame, transmission, axles, brakes, injectors, turbo, fuel system
E99 has a inter cooler, electric fuel, 4 wheel disk brakes, optional 4 wheel ABS, 4R100 auto or ZF6 auto transmission, 120cc split shot injectors injectors, hydra boost brakes, electric vacuum pump, supercabs have 4 doors, Dana 50 solid front axle or Dana 60 in DRW, 10.5 Sterling rear, oil filler extension, may not have a cat, 8x170 lug pattern, more head room, 3 piece rear window, better mirror options, unit bearing hubs, front rotors don't require removal of hubs
97 is a OBS, mechanical fuel, 2 wheel ABS, drum brakes in the rear, E4OD or ZF5 transmission, 90cc single shot injectors (larger split shots in CA trucks), vacuum assist brakes, mechanical vacuum pump, Dana 50 TTB front axle in 250's, Dana 60 in 350's, 10.25 Sterling rear, has a cat, dual fuel tanks, 8x6.5 lug pattern, 4 piece rear window, vent window
Old 05-31-2012, 05:46 AM
good to know. Thanks man
