Last week I replaced my OE HPOP with a T-500. At the same time I replaced the IPR and EBP sensor and tube. After everything was back together, the engine started back up after about 10 seconds of cranking. I let it idle for about 10 minutes and then drove it about 10 miles and this seemed to get rid of any roughness. There was a noticeable difference in acceleration, cruising speed, and throttle response with the T-500 installed. Now I am starting to experience some rough idling once the engine is fully warmed up. It still idles very smoothly upon starting, but once it is up to operating temperature it gets a little rough when idling.
Prior to this the engine ran and idled as smooth as butter, but I would occasionally get a P1211 code, hence the reason for upgrading to the T-500. I didn’t purge any air out at the ICP because it started running smoothly so quickly so I didn’t see the need. I am running Rotella 15W-40.
Any ideas?
Any ideas?
