stuttering - Ford Powerstroke Diesel Forum
post #1 of 9 Old 05-29-2012, 06:52 PM Thread Starter
stuttering
I have a 99 psd, and after getting on the throttle a bit then letting off it seems to stutter, s if its nit getting enough fuel. Any ideas on what it is? It got better when I switched tuners
early99smoker is offline
post #2 of 9 Old 05-30-2012, 06:12 AM
7.3HeavyHauler's Avatar
Is it doing that without the tuner?
My avatar is my goal for the 7.3
7.3HeavyHauler is offline
post #3 of 9 Old 05-31-2012, 08:11 AM Thread Starter
no it doesn't
post #4 of 9 Old 06-03-2012, 01:19 AM Thread Starter
Actually it does
post #5 of 9 Old 06-03-2012, 06:53 AM
i have simialar issues kinda vibrates some? i have not figured it out yet mines e99 too idk if maybe its fueling issue or maybe i was thinkin i got a ujoint or driveshaft goin maybe though...i had simalar issue with my camaro b4 that d!#@ split shaft went out on me...
E99 350 ext cab lb drw, diy cold air, boost egt trans voltage on the a piller, 4 inch too dual 4 turnouts above the cab, 80% nozzles, diy propane feed, fresh rebuild on trans with billet converter... o and a ts 6pos with canned tunes(for now)...
CMCA swartzkrautheim is offline
post #6 of 9 Old 06-03-2012, 10:17 AM Thread Starter
Would bad valves cause it?
post #7 of 9 Old 06-03-2012, 10:25 AM
jesilvas's Avatar
Quoted: 2 Post(s)
So heavy accel then no throttle at all does this?
I made my Samsung SGH-I997 send this.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #8 of 9 Old 06-03-2012, 10:27 AM Thread Starter
Yes, sometimes even after light throttle but not nearly as common
post #9 of 9 Old 06-03-2012, 10:31 AM
jesilvas's Avatar
Quoted: 2 Post(s)
Could be many things. Drive shaft or components all of a sudden not being torqued
4R100, 2wd
330,000 + miles
jesilvas is offline
