FS-2500 Bypass Filter System?
Anybody running one? I'm seriously looking at buying it for my truck
Ford 7.3 F-250 through F-550 Engine Kit - Stainless |
Not worth it, it still wont do anything about shearing which is the main problem with heui
aside from what bruce said, that is pretty pricey for something that looks to be exactly this....
Ford 6.0, 6.4 and 7.3 Oil Bypass Systems and Billet Aluminum Filter Caps |
no problem. I have been looking into getting one but just decided to run the BFOF instead, Its a killer filter and goes in stock location. Check out the donaldson filter Oil filter, ELF7405, Donaldson
Read up, if you cant graspe what you read then I'll break it down barney style
Effects of Shearing |
if you compare the specs of the stock one and the donaldson one its night and day difference in efficiency.
not really a 1995 mc is like 18 micron absolute and the donaldson is like 15 micron absolute
yeah and like 7micron 50%, stock filter is nowhere near that, ok had to look it up, but
stock motorcraft filter is Product Specs Diameter In Inches 4.25 Length In Inches 7.84 Thread Size 1 1/2 - 16 ADB Valve Material N/A RVOP Setting PSI N/A Efficiency @ 20 Micron's % 68% Capacity gr 30 Burst Pressure PSI 200 Elf7405 •Thread Size: 1 1/2-16 •Length: 11.73" (298 mm) •Outer Diameter: 4.65" (118 mm) •Gasket OD: 4.32" (110 mm) •Gasket ID: 3.85" (98 mm) •Efficiency 99%: 15 Micron •Primary Application: CAT ENGINES •Alternate Part: P554105-STANDARD (118 MM DIA) •Alternate Part: P554005-STANDARD (135 MM DIA) •Country of Origin: US (United States) •Pieces Per Pallet: 216 as well as 7 micron at 50% Last edited by campbellflage; 05-30-2012 at 02:01 PM. |
