Still leaking oil - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-29-2012, 04:57 PM Thread Starter
Still leaking oil
According to 2 mechanics the hpop was bad. I just finished installing a T500. Started the truck and let it idle for about 5 minutes while I looked for leaks. No leaks. I drove around the block and looked again. I have oil on the motor right behind the hpop. I dont see where it is coming from. Any ideas?
2002 f350 crew cab dually
T500
only mod so far
canelane is offline
post #2 of 4 Old 05-29-2012, 05:26 PM
Codum's Avatar
Clean all the oil off with degreaser and water, dry out the valley with paper towels. Get a mirror and flash light. Best to do this in a low light condition, not bright sun. Start it up and climb up their and watch it run. Your mirror needs to be small enough to get down in the valley and look under the hoop. Make sure you have tight fitting cloths on and nothing loose that can get caught on the fan or belt. It may have to warm up to start leaking, but if you miss the start of it, you'll have to start over to see where it's coming from. Good luck!
2002 F250 CCSB Lariet 7.3 Auto
2" helper springs 285/75R16 Toyo M/T
80 gallon fuel tank in bed
DIY 6637
Warn Premium Hubs
Ford Transmission @ 407,425 miles 3/24/12
Full Force Injectors
Avic X930BT w/ backup camera
"We Farm for Ducks"
As of 6/11/16 605,552 miles
2005 Excursion Eddie Bauer 4X4 6.0
Stock 225k miles
Codum is offline
post #3 of 4 Old 06-08-2012, 03:07 PM Thread Starter
You are right. It was residual oil. I sprayed the heck out of it with degreaser and hosed it down. No more leak. Thank you!!!
T500
only mod so far
canelane is offline
post #4 of 4 Old 06-08-2012, 04:25 PM
Codum's Avatar
Glad to hear.
DIY 6637
Warn Premium Hubs
"We Farm for Ducks"
Stock 225k miles
Codum is offline
