im looking for rear diff parts
*edit*
apparently i do have a limited slip according to my vin and door jamb codes 3.73 LS, i guess my clutches need a rebuild to solve the one wheel spin issue along with some good fresh fluid my truck has an open rear and i HATE it, i want to buy a limited slip or a locker and put it in there, not a fan of spools though because of the crappy handling what is the best website to buy these parts? Last edited by mcyrana; 05-29-2012 at 06:33 PM. |
any off road shop or site should have what you need. Home Page this is where most off road shops order from but you might try a local shop, they normally give you a better rate with order and install
it should have a limited slip in it
go LSD and the repack the clutches and you'll have something similar to a posi traction theres a thread on here about it. when ever I get some time I'm doing this to mine.
unfortunately mine doesnt :/
if i burn out its a 1 wheel peel and when i jacked the *** end up i was able to hold one tire still with my hands while the other was going |
ok apparently my truck comes with the limited slip 3.73 gears
i guess i need a clutch rebuild? |
got my detroit locker bearings races shims seals and all from randys for like 900 for my 3.73 d80 wlsd 3.73 thin only way to go!
