01 motor in a early 99 ecu qestion - Ford Powerstroke Diesel Forum
Old 05-29-2012, 09:44 AM
i was curious if the early 99 ecu is the same as the 00+. to me it feels like the ecu is wrong for the motor. do they differ from 99 to the newer ones? could i send my ealy 99 ecu out and flash it to this motor?
Old 05-29-2012, 10:54 AM
If your early 99 PCM is and XLE coded box...it will work, but not as good as one that is coded for that year motor. I believe that Jody at DP-Tuner can flash early 99 pcm's now to later tuning...but you might want to check just to be sure. Even without the newer motor...I would still recommend getting a new flash to the pcm...or just upgrading to a newer pcm. I went to a PMT coded pcm...and the truck shifts and drives so much better.
Old 05-30-2012, 12:28 PM
or get a ts 6pos with custom tunes thatll overide anything the pcm has on it and give you an extra little pep...JMO
