IPR replaced how much oil - Ford Powerstroke Diesel Forum
Old 05-28-2012, 03:50 AM
Well here is the question I replaced my IPR and have read that it will lose a a lot of oil so be ready with some rags. Well when I pulled out the IPR all I got was a about a 1/2 cup of oil is this the amount I should have seen? All started with a starting issue very long crank time 15 to 20 seconds.
Old 05-28-2012, 10:51 PM
Sounds about right... Not to worry.
Old 05-29-2012, 03:26 AM
Cool I had to ask most times with these trucks when some one says a lot of oil that is what you see thanks
Old 05-29-2012, 04:21 AM
It's a starting issue cause the HPOP reservoir was empty so cranking, the LPOP had to fill it up. Then the HPOP had to push all the air out of the injectors.
Old 05-29-2012, 02:31 PM
Hope so still long crank times about 15 to 20 seconds then starts and seems to run fine. Does this every time when starting if it sits for 5 min or 5 hours. Has me puzzled trying to get it scanned and see if that tells me any thing it has no check engine light.
Old 05-29-2012, 03:01 PM
Have you driven it hard since doing the work?
Old 05-29-2012, 03:09 PM
Not to much since I changed it out will be taking it out tomorrow and go down the highway just got a scanner to do live data see what comes up
Old 05-30-2012, 08:43 AM
You have to drive it for a bit to get air out of the rails and such...
Old 05-30-2012, 05:09 PM
Well scanned it tonight and pulled codes that reference the IPR cleared all and will run it for a day or two then rescan. The IPR I used was a used one from a spare motor I had. See what happens will have to shop out a new IPR maybe
