Missing at 1400-1700 RPMs - Ford Powerstroke Diesel Forum
Old 05-25-2012, 04:18 AM
Hello! I'm driving a late 1999 F250 7.3 E4OD 4X4 Off Road with 273,000 miles. Gong down the road at about 55mph, which depending on the hills is about 1400-1700 rpms, my truck acts like it is sucking air or has water in the fuel. Any ideas? I replaced the fuel filter and I am good on oil. It is only at this rpm range. I can back off and it evens out or I can speed up...
Old 05-25-2012, 07:29 PM
Doesn't your truck have 4r100?
Old 05-25-2012, 07:52 PM
I have an 02 F350 and mine is doing the same thing. It seems to be a little worse if the truck isnt warmed up yet. I havent been able to figure mine out either.
Old 05-26-2012, 08:48 AM
No, pretty sure its E4OD.....
Old 05-26-2012, 08:49 AM
Yeah, if I let it set for about 15-20 minutes it seems better but it's still annoying.....
Old 05-26-2012, 09:45 AM
when was the last oil change? was there any junk in the fuel filter when you changed it? might be water in the fuel.
Old 05-26-2012, 10:34 AM
All superdutys have the 4r100
Old 05-26-2012, 07:50 PM
Um... The oil I believe was changed just before I purchased the truck a month ago... The fuel filter looked dirty but I didn't see any water...
Old 05-26-2012, 07:54 PM
Hmm. You're right they did. I guess I do have the 4r100....
Old 05-27-2012, 08:26 AM
check the valve cover harness and run some diesel kleen thru it. if thats not it, get it scanned. don't throw parts at it. i made that mistake once, won't do it again
