Overhead Console issues - Ford Powerstroke Diesel Forum
Old 05-24-2012, 11:22 AM
When i got my truck the overhead console never worked so i took it apart to find that 2 resistors separated from the board. i resoldered them to the board and now it works great but the display shows the instant MPG but it cant be selected
im in a 2001 F350 lariat crew cab
Old 05-24-2012, 07:46 PM
Are you saying that you can see a instant MPG section in the LCD? If that's the case, I think it's normal. My 00 has that spot in the LCD but no way to select it that I am aware of. It's probably for another vehicle that uses the same LCD. Regardless, the overhead is referred to as a lie-o-meter when it comes to MPG readings.
Old 05-25-2012, 02:33 AM
Exactly. You worded it better than i could have
Old 05-26-2012, 06:37 PM
what is the trick to getting the overhead console down?? I cant see any screws and i need to replace the doors. Thanks for any and all suggestions. It is on an 02 f250 superduty crew cab
Old 05-26-2012, 06:46 PM
POP 2 CLIPS ON BOTH SIDES HERE
POP 2 CLIPS ON BOTH SIDES DOWN HERE TOO
PUSH THESE 2 TABS IN (on both sides) WHILE PULLING DOWN AND THE WHOLE CONSOLE SHOULD POP DOWN
