Fuel bowl issues - Ford Powerstroke Diesel Forum
Old 05-23-2012, 04:38 PM
Fuel bowl issues
I have a friend with a 2001 F250 superduty, the previous owner jerry rigged the fuel line on the top right of the fuel bowl and now it is leaking. I don't know what the part is called and what the fuel line is called, and I need to find some replacements. Can anybody tell me what it's called so I can get this fixed?
Old 05-23-2012, 05:28 PM
that is the fuel pressure regulator...line going out is the fuel return line
Old 05-23-2012, 05:44 PM
I found a replacement fpr housing. Now I need to find a replacement fuel return line. Anybody happen to have a part number or a website where I could find that line?
Old 05-26-2012, 10:34 PM
That is actually a fuel pressure relief valve, check with your local dealer for the part. You can also check with the local international dealer. Most of the parts guys will know what you are looking for. Just tell them that you need the return line off the fuel pressure relief valve. you can also cut it and reflare.
