2000 f350 7.3 clutch
Would this be a hydraulic clutch or not? Local shop said this was a switch ovrr year some were and some weren't. Never heard that before but just wondering if its hydraulic or not. Thanks in advance.
Anyone? Please and thanks.
my early '99 is a hyd clutch, and a 6sp trans... once they switched to the superduty body in '98, and labeled it a '99, I thought all man trans were 6 sp, and have never heard of a non-hyd clutch...
Yea found out it is a hydraulic clutch but mines only a 5 speed has l-5
No low/bulldog gear below reverse? Should have the shift pattern with reverse being full left and up, with reverse, 1, 3, 5 across the top, low (granny gear, bulldog, whatever term you prefer) directly below reverse, and then across the bottom, starting at low, 2, and 4, in the standard H type pattern.
R 1 3 5 L 2 4 Gives you 6 forward gears, even though overdrive is labeled 5th. If that's not the case, yours is the first Superduty I've heard of with a 5 speed. Is it factory? |
Yea that's how mine is I thought that was considered 5 speed though not a 6 cuz it technically doesbt have the 6th label gear may be wrong though but I know on some cummins they have 1-6 but guess that make up for l-5 but please correct me if I'm wrong
Yup, called a 6 sp, like I have in my red truck... I like rowin' gears, wish my other trucks were sticks.
What would be the zf5 pattern then and yea I love having control over my gears only reason I bought this truck I wasnt gonna cuz of it being 2wd but i don't get bad winters.and knew I wasn't gonna be lifting a dually so i said **** it it works fine for what I do with it
I think the ZF-5 pattern, reverse is below 5th, to the right and down, but I could be wrong, I've never driven one that I KNOW to be a ZF-5... but I though it was right and down. I'm glad they changed it on the ZF-6, makes more sence to me to have reverse and low gears closer, not on oppiset sides of the shift pattern, like the ol' chevy I learned to drive on...
Yea your probably right sounds like it'd be that way
