Up pipe leak or weak wastegate actuator - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-21-2012, 03:27 PM Thread Starter
Hey guys, I can get to 22 pounds of boost on both of my highest chip settings and only 12 on stock. When I unplug my actuator I still get to same amount. I made sure none of my boots were leaking. I think it's the actuator getting weak but I want to be sure before I just throw money at it. Thanks in advance.
rlawrence110 is offline
post #2 of 6 Old 05-22-2012, 05:25 AM
jesilvas's Avatar
Quoted: 2 Post(s)
What chip?
How did you make sure the boots weren't leaking? Best way is to pressurize the intake system while the truck is off.
If the exhaust is leaking preturbo, you should see soot marks around any connections.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 6 Old 05-23-2012, 02:45 PM Thread Starter
I built a boost leak detector like you said and saw my ebp tube mounting bracket was leaking Pretty bad where is presses against the hpop(I guess that's what it is) at about 5 psi. Do you know where I can get a new one or if it's good to try to reveal it? I guess I messed it up when I was cleaning it not too long ago.
post #4 of 6 Old 05-23-2012, 03:48 PM
jesilvas's Avatar
Quoted: 2 Post(s)
So you pressurized the intake and exhaust sides both?
I'd replace it, but not for the fact that it's going to lose so much exhaust as to affect turbo performance, but that it's losing so much exhaust as to not let the PCM see actual EBP reading, thus affecting performance possibly.
Driven Diesel HPOP Access Cover Kit - Nice little piece.
Riffraff Diesel: Exhaust Back Pressure Tube - OEM
4R100, 2wd
330,000 + miles
jesilvas is offline
post #5 of 6 Old 05-24-2012, 12:24 PM Thread Starter
i just put air in through the inake side. How would you test the exhaust side? I understand that the tube is connected to the exhaust side but I thought you would have to block off the exhaust pipe.
I'll fix it this weekend probably. Thanks for to help I appreciate it
post #6 of 6 Old 05-24-2012, 03:40 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Well you said the EBP is leaking at about 5PSI
4R100, 2wd
330,000 + miles
jesilvas is offline
Tags
leaak , wastegate actuator
