ccv mod/cc filter - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-21-2012, 02:31 PM Thread Starter
Tivs's Avatar
ccv mod/cc filter
I bought a crank case filter. Bored out the rubber and drilled a hole in the filter to drain oil it seems to work great. Thoughts?
SOLD: 99.5 F-250 ECLB, Zoodad mod, aih delete, 22k mod, wix 46637,16.5s wrapped with 35x12.50 BFG T/As s, ccv mod, 140v IDM, heater core ball valve mod, 324,000 miles
95 F-250 ECLB, E4OD, 3in turbo back straight piped, diy intake w/ 6637 and riffraff prefilter, cool go fast stickers, 140v idm, need new ball joints and king pins...negative camber is out of this world. 266k miles
Tivs is offline
post #2 of 12 Old 05-21-2012, 04:56 PM
Quoted: 143 Post(s)
Feedback Score: 3 reviews
Got a pic? I'm having a hard time picturing what it is you have...
A "Crankcase Filter"? From where or what?
What I don't like about the whole Filter idea, is that filters clog and a clogged CCV can lead to pressure inside the motor that builds quickly and pushes oil through every seal it can
NoRalPh is offline
post #3 of 12 Old 05-21-2012, 06:01 PM Thread Starter
Tivs's Avatar
Ya any autozone carries a crank case vent filter. Ya I have pics is there a way I can upload them on this discussion without uploading them on photobucket
Tivs is offline
post #4 of 12 Old 05-21-2012, 06:02 PM Thread Starter
Tivs's Avatar
And I drilled a hole in the bottom of the filter so the oil can drain
Tivs is offline
post #5 of 12 Old 05-22-2012, 08:27 AM
I think that you made a mistake. There is no reason to have a filter on the end of a diesel's crankcase vent. It is an exit-only opening unlike a gasoline engine where the PCV system actually draws air into the engine through the CCV which is why the filter is made.
IH designed this engine to be able to vent the crankcase fumes through an open ended tube. Anything else has potential to damage the engine.
2000 F350 4wd CC SB PSD
Normal mods plus gauges and PHP chip
Lowered to F250 height
Stock tire size, looks stock.
18' 10k# equipment trailer
30' Travel Trailer 7500#
Kioti CK30 tractor
Kawasaki KLX250s Dual Sport
Highbeam is offline
post #6 of 12 Old 05-22-2012, 11:25 AM Thread Starter
Tivs's Avatar
Well take a 4.0 for example it uses the ccv to heat the air going into the intake. So when I built a intake for my jeep I used the filter to prevent the engine bay from filling from gases. I looked it up afterwards and that's what I was suppose to do. The gases can pass through the filter. I also made it so if it builds to much pressure the filter will pop out before the pressure hurts the motor. So can I upload pics w/o photo bucket
Tivs is offline
post #7 of 12 Old 05-22-2012, 11:57 AM
lhsnbsaoa's Avatar
Garage
... this doesn't sound quite right. I put a filter (more of a catch can) on my CCV tube on my 6.4. It is just catching some of the oil before the air goes back into the intake.
1996 F350 Dually Centurion
Previous trucks: 2003 F-250, 1997 F-350 CCLB, 2000 F-350 CCLB, 2008 F-250 CCLB
lhsnbsaoa is offline
post #8 of 12 Old 05-22-2012, 01:50 PM
Demo250's Avatar
I see no point in this. Like stated earlier, the CCV is just a tube that drips oil. You drilled a hole in a filter so that the oil could drip out. What exactly are you filtering, especially when the filter has a hole in it? I don't even get it....
And yes, you can upload pics without photobucket. Click post reply and then scroll down till you see "manage attachments" and then upload. Or if you want an image hosting site that you don't need an account for, just use: TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
Demo250 is offline
post #9 of 12 Old 05-23-2012, 12:14 PM Thread Starter
Tivs's Avatar
All I know is with the filter there is less fumes but the filter is still breathable. But I don't wanna run the risk of over pressure so I'm going to run stainless steel tubing
Tivs is offline
post #10 of 12 Old 05-23-2012, 12:20 PM
lhsnbsaoa's Avatar
Garage
Am I the only one that is confused about what your talking about?.... with that being said.......
