Foil Delete?
To those of you that have already done this. What did you use to get the glue off of the pipes. Im getting them powdercoated, but having a hell of a time gettin them clean.
i used prep-sol and a razor. prep-sol is pretty hard to find though.
purple powers and a scotchbrite pad works great, soak it with pp like 3 times scrub and hit couple times should do it...
power not powers
You could use some adhesive remover. We have some that just says "adhesive remover" on the pail. No name, ingredients or anything.
![]() But it's good. I used a wire wheel on a drill. Just took lots of time. |
Laquer thinner will eat it right off too. Just soak it for a min and brush it off.
Xylene, it's mean stuff you Do Not want to breathe the vapors, but was the best solvent I tried along with a wire brush..
x2, it what I used...
I just used some "Goo Be Gone." Or something like that anyway... still took a bit of time but it definitely softened it up a lot.
goof off works well. I used green pads and possibly razor blades IIRC
