7.3 Oil Capacity - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 13 Old 05-19-2012, 07:44 PM Thread Starter
E-Man's Avatar
7.3 Oil Capacity
Ive read on a few different forums some people using 14 quarts with their oil changes in the 7.3 and some using 15. My manual says to use 15 quarts (including what you put in the new filter prior to installing it). I did my last oil change and installed a little under 15 quarts, including what I put in the new filter before twisting it on. With just under 15 quarts, the oil level reads about 1 inch above the cross marks on the dipstick. I gave the truck plenty of time (about 15 minutes) to drain the old oil before putting the drain plug back on. My question is to all of you guys using 15, like the manual says, does your dipstick level read high? I know that some oil stays in the HPOP, but from what ive read online that oil is not figured into the 15 quart refill recommendation.
2001 F-250 CC SB 4x4 Off-Road w/ 88k miles on the 7.3. 4" lift on 35" BFGs. All synthetic fluids (Amsoil & Schaeffer's)
S&B intake, 4" turbo-back straight-pipe, 6.0 trans cooler, Dieselsite coolant filter w/ Delo ELC, Isspro gauges, Mag Hy-Tec diff cover
2012 tailgate, rear bumper, and tailights
2001 Excursion Limited
Only 55k miles on the 7.3
Bone stock
E-Man is offline
post #2 of 13 Old 05-19-2012, 07:50 PM
did you start it let it run for a min shut down then check it? (COMMON MISTAKE!)
E99 350 ext cab lb drw, diy cold air, boost egt trans voltage on the a piller, 4 inch too dual 4 turnouts above the cab, 80% nozzles, diy propane feed, fresh rebuild on trans with billet converter... o and a ts 6pos with canned tunes(for now)...
CMCA swartzkrautheim is offline
post #3 of 13 Old 05-19-2012, 07:53 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
15 quarts is the amount of oil to put in.
Sent from my Acer Android Tablet
rednex3 likes this.
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #4 of 13 Old 05-19-2012, 07:57 PM
jesilvas's Avatar
Quoted: 2 Post(s)
15qts is the amount with a filter chance.
The HPOP reservoir and HPO railsaren't figured into the change capacity.
If you don't start it and let it circulate, the figure will read high.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #5 of 13 Old 05-19-2012, 08:18 PM Thread Starter
E-Man's Avatar
I last changed it a few months ago. It's been started and run many times since the change and still reads a little high. I just checked my old Amsoil bottles out in the shed and I definetely only put about 14.75 quarts in. Thats with using a stock Motorcraft filter. Like I said, I let the truck sit for quite a while before re-installing the drain plug...and when I did there was no old oil dripping out at all. So you guys that run 15 quarts, your dipstick doesn't read a little high?
When I bought the truck, the previous owner had written "14 QUARTS" with a grease pen on the fan shroud...im guessing the dipstick must've read high for him too when he put 15 in.
Bone stock
E-Man is offline
post #6 of 13 Old 05-19-2012, 08:31 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Nope. Not high on my stick . . .
What year motor is in it and what is the trucks build date?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #7 of 13 Old 05-19-2012, 08:34 PM
hmm i wonder what happend to your extra qt, they must have took something out of the oil system...i just wonder what
post #8 of 13 Old 05-19-2012, 08:44 PM
sldghamr's Avatar
16 quarts in the entire engine (including HPOP). 1.5 quarts for the filter & 13.5 in the pan..........
if you see a light at the end of the tunnel, it's probably just a photon torpedo
sldghamr is offline
post #9 of 13 Old 05-19-2012, 08:44 PM Thread Starter
E-Man's Avatar
Stock original motor with about 87k miles on it. Doesn't leak or burn any fluids. I believe its a April or May 2001 build date. Maybe im letting it sit for too long after shutting it off before checking it (still fairly new to diesels). Ill usually let it sit for 10-15 minutes after shut down to check it. How long are you guys waiting?
Bone stock
E-Man is offline
post #10 of 13 Old 05-20-2012, 06:01 AM
jesilvas's Avatar
Quoted: 2 Post(s)
That should be fine.
The reason I ask is because OBS 7.3 motors take 14 qts.
You SURE it's the original motor?
4R100, 2wd
330,000 + miles
jesilvas is offline
