help first time buying a diesel - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-16-2012, 10:34 PM Thread Starter
i have a 03 f250 5.4 4wd lifted that gets 8.5 mpg. i am looking at two diesel first is a 2000 f250 7.3 4wd with 244,000 for $8000 or a 1999 f250 7.3 4wd 6 speed with 220,000 for $9900. not real sure if i will end up saving money because of the price of diesel. Just looking for some advice?
Thanks
rfraub is offline
post #2 of 5 Old 05-17-2012, 04:33 AM
zrain25's Avatar
Pe
Early 99 201,000 miles. Extra spring up front leveled, 4 in turbo back to 6 in tip, 6637, glow shift gauges, dp tuner, kicker speakers, alpine head unit and amp, kicker sub, extang tonneau, bedliner bumpers grill, flares, and rockers, 33in toyo mt, 18in xd monsters, 05 Harley lights, recon tails and line of fire, 20% tint
zrain25 is offline
post #3 of 5 Old 05-17-2012, 05:24 AM
Quoted: 14 Post(s)
The big savings comes when you start putting weight behind the truck. My 2000 F-350 got 12mpg towing a trailer in the mountains where my old '71 F250 with a 390 gas motor got 6.
ttyR2 is offline
post #4 of 5 Old 05-17-2012, 06:56 AM Thread Starter
Pe? Im not sure what you mean
rfraub is offline
post #5 of 5 Old 05-18-2012, 10:37 PM
Well it would help if you had any records with the trucks, with that mileage you're bound to have some isuess, for example my truck (2000 F350 PSD). Similar mileage bought it with 277k on it and also my first diesel, here is the list of the stuff i've done so far:
speedometer cluster(speedo didn't work)
fixed all door lock actuators
transmision(took a **** a week after I bought it)
tensioner and belt
droped the tank and removed filters which were cloged also pickup broke off and had to be replaced
cleaned fuel bowl
replaced fuel return spring
cleaned cloged back pressure sensor tube
sway bar links
rear diff. fluid
6637 filter
injector control sensor and plug
still to come
both batteries
glow plugs and relay
I did all the work myself(except rebulding the trans) so it wasn't that bad money wise, but still a lot of work. So make sure you do your research
Tomsf350 is offline
