Old 09-30-2007, 09:10 AM
eaton34 eaton34 is offline
WHAT ELSE???
Since i found out that i need to replace one or some of my injectors sleeves i am going to put a little money in my rig. here is what i have in mind so far, any suggestions would be great of things that i might think about doing as well.
diy injectors 50 hp
ts 6 pos chip
diy intake
4" down pipe w/ 5" straght pipe
fpr shim
I think that these will wake my truck up! I have read about all the mods and just would like to hear what i might be missing. YES i have guages.
Old 09-30-2007, 09:35 AM
Blue01F250 Blue01F250 is offline
Tournaments Won: 1
Make that a Tony Wildman (www.totaldieselperformance.com) or DP chip (both will kick the snot outta the plain TS, plus can burn your tunes with whatever mods you have/get) and ya don't need 5" unless ya just like it
do the zoodad if you have a late 99 & up and you should be good
Old 09-30-2007, 09:38 AM
najaf4life najaf4life is offline
One Nation Under God
i'd go with tony if I was you... been told that he will reburn your chip if you are not happy with it or if you get other mods down the road he will reburn it for that reason also....
Old 09-30-2007, 09:51 PM
lilredpowerstroke lilredpowerstroke is offline
Powerstroke Pimpin'!!!!!!
What year is your truck?? If its pre 2001 the I would get bigger injectors than the stage 1's. I know if mine didn't have the PMR's I would be kicking myself in the rear for not going bigger on the sticks.
Old 10-01-2007, 08:20 AM
My truck is a 99. I would love to go bigger on the injectors but like the rest of us i only have so much money! Here's the question then...do i go stage 2 injectors and no ts chip or do i get what i have listed? What will run and be the most reliable?
Old 10-01-2007, 12:50 PM
alabamafrog alabamafrog is offline
Powerstroke Techie
Get the chip, injectors are nice but you will need a chip to run them anyway. So far I really like my injectors I got from Swamps for about $1500, much cheaper than stock and a lot stronger too but they didn't make as big a difference as the chip did and I have to have a chip to run them anyway. I got my TS chip for about $300 originally it was stock,HI,50HP,80HP,100HP,140+ and I loved it. When I got the new injectors swamps reburned it to run them and now apparently I need a bigger HPOP to get my power back.
