Old 10-20-2005, 09:01 PM
F-350MAN F-350MAN is offline
GOD RULES!!!!!!!!
bonehead move????
I pulled a bonehead move the other day I left my key in the on position without the engine running, thank GOD it started up, but could this do any damage to the glowplugs or anything besides the batteries? I forgot to mention that it was a 4 hr. period.............. :
Old 10-20-2005, 09:19 PM
Andy Andy is offline
Administrator
As far as glowplugs go, dont the newer trucks like yours shut off automatically after they have been warmed up? Besides running down the batteries, I dont see much else that you could have done. Anybody else?
Old 10-21-2005, 06:17 AM
overl0rd overl0rd is offline
Send a message via ICQ to overl0rd Send a message via AIM to overl0rd
The glowplugs will shut off automatically anywhere from I think 30 seconds to 5 minutes after the ignition is turned on, depending on the temperature. Leaving the key on wont hurt them, at worst you'd end up with dead batteries.
Old 10-21-2005, 01:53 PM
powerstrokekiller powerstrokekiller is offline
Send a message via AIM to powerstrokekiller
Yea, the owner's manual on my cummins says that if you leave it in the on position for more than two minutes without startin it up you should redo the whole cycle. The glow plugs warm up for a set period than they cool off. Pretty simple actually. It's on a timer.
Old 10-21-2005, 03:39 PM
jwiger jwiger is offline
Military Member
Send a message via ICQ to jwiger Send a message via AIM to jwiger Send a message via MSN to jwiger Send a message via Yahoo to jwiger
you should be fine. i know in a gas engine you can hurt the ignition system but.....
Old 10-21-2005, 04:00 PM
On gassers, the old leaving the ignition on myth will actuallly do burn the points resulting in premature failure. On modern electronic ignition motors no harm is done.
Old 10-30-2005, 04:36 PM
wiwaniuk wiwaniuk is offline
According to my 7.3 manual, the glow plugs stay on for 2 minutes on a cold engine. If you leave the ignition on longer without starting the engine, you have to shut off the key to reset the glow plug timer.
