Compresser sound near pass. side battery - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-02-2012, 05:42 PM Thread Starter
Might be a stupid question and I tried searching, but what is that little compresser near the passenger side battery. Not sure what it is, but it sounds like a compresser.
potbss is offline
post #2 of 12 Old 05-02-2012, 05:45 PM
its a very small vacuum pump to run your HVAC mode selector door, and if your truck is a 4wd with the electric switch, it locks your hubs.
the trav is offline
post #3 of 12 Old 05-02-2012, 06:01 PM Thread Starter
I have the turn knob for the 4x4, but I have to lock the hubs manually. whats hvac?
potbss is offline
post #4 of 12 Old 05-02-2012, 06:32 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Heating, ventilation, ac.
Changes your blend door from floor, vent, and defrost.
Your hubs won't auto engage cause you have a vacuum leak/loss of vacuum to the front hubs. I bet when you auto engage them, the air goes to defrost only.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #5 of 12 Old 05-02-2012, 06:37 PM Thread Starter
I have to turn the hubs by hand. theres arrows on there that say unlock and lock. inside the truck theres a knob for 2x4. 4x4 and 4x4 low
potbss is offline
post #6 of 12 Old 05-02-2012, 08:51 PM
JSchuricht's Avatar
You have manual hubs. Auto hubs say auto and locked. Consider yourself lucky, one less source of a vacuum leak.
JSchuricht is offline
post #7 of 12 Old 03-05-2013, 04:59 PM Thread Starter
old post but, should i replace the pump first. it runs non stop. the hvac controls don't work either.
2003 F250 7.3 CC SB FX4
TS Chip Tuned by Tony Wildman
4" MBRP Turbo Back Straight Pipe
Driven Diesel Regulated Return
International Bellowed Up-pipes
K&N Intake W/ 6637
Transgo Shift Kit
ATS Ported Turbo Housing
Wicked Wheel 2
EBPV Delete Pedestal-High Flow Outlet
3 Gauge Pillar Pod
Viper Remote Start w/Turbo Timer
potbss is offline
post #8 of 12 Old 03-05-2013, 05:00 PM
jesilvas's Avatar
Quoted: 2 Post(s)
If it runs non stop you have a vacuum leak.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #9 of 12 Old 03-05-2013, 05:58 PM
over200's Avatar
Quoted: 5 Post(s)
Does the pump have a fuse? If the pump isn't working at all is it fried??
2000 F350 CCLB 536 k+ miles still runs like a top!
Diablo chip, quickie pedal, valve body, Air Force One air intake, MBRP system, XD Diesels w/ MT ATZ's, KL5H Train Horns / Air Zenith supplied.
over200 is offline
post #10 of 12 Old 03-05-2013, 06:26 PM Thread Starter
Were should I look for the leak? The hvac controls? The pump is always on. Never turns off. I was just going to buy a new one.
K&N Intake W/ 6637
Transgo Shift Kit
Wicked Wheel 2
3 Gauge Pillar Pod
potbss is offline
