hole in diff cover - Ford Powerstroke Diesel Forum
post #1 of 11 Old 04-30-2012, 02:20 PM Thread Starter
dentexpowerstroke's Avatar
hole in diff cover
Drove my truck about 5 miles today and when i parked it I noticed what diff fluid on the ground from where it was parked last nght looked and there was a pinky sized hole in the cover. Anyone ever have that happen or know what would cause that. It drove fine before I noticed. I didn't hear any pops or anything last night when I drove it. Fluid was changed not to long ago. Any input would be nice before i take the cover off tonight.
Sold 2001 f250 ccsb 4x4 400/400, dual terminators, swamps 80mm bfh, headers, bts and all the usual supporting mods. 715hp fuel only.
06 f250 ccsb king ranch
12 f250 lariat ultimate
dentexpowerstroke is offline
post #2 of 11 Old 04-30-2012, 03:53 PM
powerram250c's Avatar
When I changed my diff oil last year my rear cover had big old rust flaked coming off of it. I ran the rust scaler over it and painted it flat black. Yours might be like mine was.
2002 SRW F-350 7.3L XLT Auto Crew Cab Short Bed
-Almost 200K miles
-Autometer Cobalt: Boost, EGT, Trans Temp
-6637 Air Filter Mod
-Coolant Filter
-Straight Pipe
-CCV Mod
-TS 6 position chip
-Recon Cab Lights
-Gentex Compass-Temp-Auto Dim Rearview Mirror
-Nathan AirChime K3HA horns
2012 Volkwagen Jetta TDI
-6 SPD
powerram250c is offline
post #3 of 11 Old 04-30-2012, 03:55 PM
ZMANN's Avatar
Quoted: 1350 Post(s)
hope it's rust
I chunked a gear and split the cover and dif housing ,, but it made a huge pop
We Miss you Ronnie
ZMANN is offline
post #4 of 11 Old 04-30-2012, 04:01 PM Thread Starter
See I haven't heard a pop but it looked like it was dented at the hole
post #5 of 11 Old 04-30-2012, 04:28 PM
desertdeer's Avatar
i have seen teeth break off the ring gear and make a hole similar to youre description. good luck. its usually cheapest to find a new rear end complete out of a part out truck
96 F250 PSD 3''DP 4'' ATS EXHAUST 6637 TS-6 5-SPEED LUK CONVERSION INTERCOOLER PROPANE 4'' LIFT 35X18'S
desertdeer is offline
post #6 of 11 Old 04-30-2012, 04:32 PM Thread Starter
That's what I figured. I didn't have time to look around the whole housing so when I get home ill see if there are any more hole anywhere. Are the obs rear axles the same as ours?
post #7 of 11 Old 04-30-2012, 05:43 PM
Tj Krawler's Avatar
OBS is 10.25 and SD is 10.5.
Where was the truck parked? My friend had someone drill a hole in his diff cover when he was in the city... parked right in front of the hospital. I would pull the cover before you look into a new axle.
Sent from my C771
Alan
2000 F-350 CC LB DRW 4x4 XLT Auto
- Intake
- Exhust
- ScanGauge
Tj Krawler is offline
post #8 of 11 Old 04-30-2012, 06:49 PM Thread Starter
I took a better look at it at lunch. The hole looks about like a screwdriver busting thru on a rusty spot. I'm hoping rust just gave out on a soft spot. Its not on the ring gear side after all.
post #9 of 11 Old 04-30-2012, 11:53 PM Thread Starter
pulled it apart and one of the spider gears shattered apart. I need it to get around the next few days, anyone know if it is driveable if i clean it all out or will the missing spider gear just cause it to grenade itself?
post #10 of 11 Old 05-01-2012, 05:28 AM
ZMANN's Avatar
I think the pin has been pulled on the grenade
We Miss you Ronnie
ZMANN is offline
