99 f350. Minor Issues Need Help - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-29-2012, 08:30 AM Thread Starter
Well I just purchased the truck and I knew it had a door ajar issue. The kicker is the driver side door has been replaced which I was also aware of. So anyways, with all oh the doors closed the door ajar light is on. And when you open the Drivers side door the light goes off????????????? Not really sure how to fix this issue, I already have the door panel removed and all the wires look fine going to the door latch. Also Im not sure which connector on the latch is the one for the door ajar. What Ive done already is remove both connectors and switched over the wires in the connectors to see if reversing the polarity fixes it, and it did not.Any help would be great! After I get this fixed still have some little stuff to fix, just gotta go one at a time.
srob817 is offline
post #2 of 8 Old 04-29-2012, 11:45 AM
Jordan72's Avatar
shoot some wd40 down in the latch and open and close the door a few times... mine did this when I first got it and drove me crazy. There is a thread somewhere around here that goes into more detail. Hopefully that works
Early 99' CCLB, 05 Harley Front End, 05 Harley Black Leather Interior, 05 Lighted Tow Mirrors, Built Trans
Jordan72 is offline
post #3 of 8 Old 04-29-2012, 02:13 PM Thread Starter
Well I dont know if that will work because when you open the door the light goes OFF and when the door is closed the Light comes ON. It seems like the wire are backwards or the switch is messed up. I have no idea???????????
srob817 is offline
post #4 of 8 Old 04-29-2012, 07:39 PM Thread Starter
still no ideas besides wd40 huh?
srob817 is offline
post #5 of 8 Old 04-30-2012, 06:21 AM Thread Starter
Im thinking about replacing the driverside door ajar switch. I got the door panel off. Where is the switch?? And how do you remove it?
Thanks
srob817 is offline
post #6 of 8 Old 05-01-2012, 08:21 AM Thread Starter
Can I get some help on this?
srob817 is offline
post #7 of 8 Old 05-03-2012, 11:55 AM
Jordan72's Avatar
Yeah I read that part wrong... that beats me but I would try the switch
Jordan72 is offline
post #8 of 8 Old 05-03-2012, 12:09 PM Thread Starter
Yeah thats what Im thinking. How do I remove it from the door?
srob817 is offline
