garret install - Ford Powerstroke Diesel Forum
post #1 of 15 Old 04-27-2012, 03:09 PM Thread Starter
garret install
hey guys I'm looking at bolting in a r38 garret.. what is necessary for the swap? any additional pointers or suggestions?
Sent from my LS670 using AutoGuide.Com Free App
cdav111 is offline
post #2 of 15 Old 04-27-2012, 03:24 PM
Quoted: 6 Post(s)
You're going to have some fun with the v-clamps, that's for sure lol.
1999 F-350 ECSB ZF6 4x4 Halfbreed:
Mods:
PHP Pheonix 6-Position Chip
Glowshift gauges (boost/egts/oil psi/fuel psi/oil temp/coolant temp/voltage
DIY 6637 Intake
5" Diamond Eye exhaust
05+ Harley Davidson Headlights
55w 5000K HIDs
Future Mods:
Shocker horns
SRP1.1
Irate turbo setup
S366
DIY fuel system with regulated return
and saving to build a mid 500hp rig.
stroker0920 is offline
post #3 of 15 Old 04-27-2012, 03:30 PM
Get a blank pedistal and a high flow outlet or dit ebpv delete. Install is as simple as unboltin one and replace
bruce51d is offline
post #4 of 15 Old 04-27-2012, 07:22 PM Thread Starter
where should I go for the pedistal? ill also be needing some o- rings
cdav111 is offline
post #5 of 15 Old 04-27-2012, 07:41 PM
pretty much everyone has them, if its a new turbo it should come with new o rings
bruce51d is offline
post #6 of 15 Old 04-27-2012, 08:25 PM
JSchuricht's Avatar
Tighten down the wastegate before installing it, it ships really loose.
JSchuricht is offline
post #7 of 15 Old 04-27-2012, 09:21 PM
steve's red stroker's Avatar
A air hammer with a 18" long bit, works great to knock the clamp loose from the up-pipes, saves a lot of time
steve's red stroker is offline
post #8 of 15 Old 04-28-2012, 06:12 AM
SS4Matt's Avatar
That is exactly what I did. I got to the point of not caring if I ruined the clamp I would have just picked up another one, but I managed to not kill it with the air hammer I just pulled my 3 month old remaned turbo off yesterday and it took me 36 minutes to remove it (15 minutes just fighting that clamp again!)
tools needed off the top of my head
11mm deep for the clamps on the turbo boots and down pipe
8mm for CCV block piece and smaller hose clamps on the intake spyder
13mm for the 2 bolts holding the turbo itself
pliers to slide the tab over for the EBPV rod
Hope and a Prayer for the up pipe V-Band clamp!
02 F-250 7.3 Powerstroke PMF Suspension 20" XD Hoss 325/60R20 Dura-Tracs
38R 4" MBRP TW Chip HPX Mod EBPV delete 6637 Billet Converter Shift Kit Autometer GS
SS4Matt is offline
post #9 of 15 Old 04-28-2012, 08:15 AM
what is the gain to going to the 38...i read it is an upgrade but have not found anything which stated you gain this with the swap
hotairgypsy is offline
post #10 of 15 Old 04-28-2012, 09:40 AM Thread Starter
honestly I don't know. its just supposed to be "better" be general consensus... any one have any #s or other input?
cdav111 is offline
