left rear brake getting hot, sometimes - Ford Powerstroke Diesel Forum
Old 04-26-2012, 04:40 PM
replaced rotors and pads all the way around, now occasionally the left rear gets smoking hot, not always just sometimes. did a search and found the same problem but no answer to it, anyone had this happen?
Old 04-26-2012, 05:25 PM
had it happen to mine and found out it was the master cylinder.replaced it and all is good
Old 04-26-2012, 05:33 PM
Check the slide pins or the caliper itself
Old 04-26-2012, 06:23 PM
slide pins are good, checked and rechecked. how would i go about checking the caliper and master cylinder?
Old 04-27-2012, 05:55 AM
Do you use your Parking Brake a lot? Could the left side be hanging-up at those times it's getting hot?
Old 04-27-2012, 06:12 AM
can be the rubber hose rotting from the inside, not releasing pressure too.
Old 04-27-2012, 06:24 AM
caliper pistons are known to hang /crack on these
I would visually inspect or just replace they are under 60 with a full hardware kit from Autozone ,,, not that I like throwing parts at stuff but you risk ruining your new pads and rotor if you don't get it resolved
Old 03-18-2013, 09:28 AM
Replace the caliper
I had the same thing happen to me. Replaced everything except the caliper... figured I would save some money... even replaced the caliper guide rods and rubber boots.... After driving about 2 miles the brake was smoking.
Replaced the caliper and connecting brake hose.
All good now.
A brake caliper is about $55.... guide rods and boots are about $15... So I should have just spent the extra $40 the first time and been done with it....
