need help with pcm - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-26-2012, 04:46 PM Thread Starter
2000dually7.3's Avatar
need help with pcm
Hey guys I'm still fairly new to this but the other day i was trying to remove my pcm so i can get the code to order my chip. Once i unbolted the wire harness then took the two bolts out in the cab right beside the ebrake peddle I tried to pull out the pcm like its suppose to. But it didn't work that way, felt like it was getting caught on the bracket. Anyone havr any tips or is their some sort of secret. Its a 2000 7.3 . Thanks in advance.
2000dually7.3 is offline
post #2 of 4 Old 04-26-2012, 05:31 PM
hammerstroker's Avatar
just pull and prey...... that u dont mess it up. it should separate pretty easy. just give it a tug. there is a 10mm bolt on the firewall on the drivers side and then them 2 7 or 8mm bolts for the bracket just wiggle it up and down it will come out
"BIG RIG" auto to zf6 swap 00 f-350 cclb dually,4in rough country lift, 6637, 7in mitre stacks, wicked wheel, foil delete,live tuned from bill at php,triple pod autometer gauges,315/75r16 kelly tsr's, 05 front end conversion, 2in spacers for rear,stage one swamps 175cc single shots,boost fooler, kennys dual disk clutch.
hammerstroker is offline
post #3 of 4 Old 04-26-2012, 10:32 PM
Quoted: 14 Post(s)
You have to move the tail end to the right until the tang on the plastic frame pops out (the tang is near the firewall end on the left side).
ttyR2 is offline
post #4 of 4 Old 04-30-2012, 05:19 PM Thread Starter
Thanks guys! The reason couldn't get the back to pop out was cuz it was catching my clutch pedal. I took the 10mm bolt out of the bottom of the bracket and popped that off and it slid right out. Thanks again for the help
Tags
7.3 , chips , mods , pcm , powerstroke
