TRAIN HORN compressor * - Ford Powerstroke Diesel Forum
Old 04-25-2012, 04:34 PM
I hooked up a toggle switch that has one wire coming from the stock horn, and one wire going to the solenoid on the train horns.. so that works good and when i flip it up it blows the stock horns, and down it makes the solenoid on the horns click, because i havent hooked up the air yet... but im a little confused on how to hook up the relay for the compressor.. i wanted to put an on/off switch on it so if the lines leak then its not constantly running, but i also wanted to hook up the pressure valve.. so when it hits 150psi it will shut off, then when it drops below 120psi it will kick on... so when i flip the switch for the compressor to on, it will run until 150psi then start running when it gets back to 120psi.. but when its off (like at night when im not using it) the compressor wont constantly keep going off and on..
any comments please
thanks
Old 04-25-2012, 05:33 PM
Run battery power to the main power connections on the relay. Then put a switched power feed through a manual switch and through a pressure switch in series feeding the "control" connection on the relay. Pretty simple, really.
Old 04-26-2012, 03:59 PM
Location: Lowville, New York. Studying Mechanical Eng. @ Suny Canton
haha what? Sorry wiring always gets the best of me. im looking to do this on my rig as well
Old 04-26-2012, 04:17 PM
Where did you hook the solonoid for the air horn in to? Ive been wanting to do this for a while
Sent from my C771 using AutoGuide.Com Free
Old 04-26-2012, 05:54 PM
I bought something like this to control my air compressor for my air set up. It's everything in one.
105 PSI Pressure Switch For Train Horn Air Compressor | eBay
