4r100 bypass tube elimanator
My bypass tube is starting on leak around the banjo bolt and I found the bypass tube elimanator just wanted to see if anybody was running it and how they like it thanks for input
I run one. You will only see a difference if it's leaking or the tube is staying open causing the transmission to overheat. The E40D in the older trucks is 99% the same as the 4R100 and does not use a bypass tube.
